Starter motor replacement on a chevy 454 7.4,(G30 Motorhome)
Hi, This is my first post. Own a 95 Chevy G30 motorhome, a 48 chevy 3100 project and a 1984 dodge ram crew cab project. This post relates to the motorhome. I have a replacement starter motor for it. I noted that it was a smaller unit, put that down to the original being 20 years old and the new one being modern. Every auto parts website i check says that this new starter is correct for my engine, The new starter is a NM6499. However i noticed when fitting that the old bolts ground out leaving about 10mm of bolt. I then phoned the suppliers who assured me that it was correct. the old starter had 9 teeth, this one has 11 teeth. I have worked out with a vernier, that if i pack the bottom of the starter motor out by 10mm then the ring gear will be within 1-2mm of the original. 10mm must be too much?? Shims are only 1mm ish and i have been told not to use more than 4 shims on a starter. Can anyone advise??
douchecalamondaes
are you talking about packing the motor out from the engine block so that the starter gear gets full contact with the ring gear (when the starter is pushed out, if its a solenoid starter)??
if so its certainly possible, but a custom plate would have to be made to get proper area contact not penny washers or any rubbish like that.
