Spark Plugs - Megasquirt RV8 4.6
I am just about to fire up my new build 4.6 RV8 - will be managed by Megasquirt with ignition by EDIS 8. The engine is not a race engine and will be used in a 4wd.
I am looking fore recommendation for spark plugs - preferably NGK brand as they are the most easily sourced locally. I am not sure whether the LR specified plugs are still relevant with MS and EDIS.
Garry
Garry
I run a programmable MSD on my stage III 4.6, I also run a 100 BHP NOS shot. I run the car on the road. I just run NGK plugs that are one grade colder than standard. From memory I run the gap at 40 thou.
EDIT...Doh, I should learn to read, I thought that your engine is a race engine! In that case I'm sure that the standard plugs will be fine.
- SimpleSimon
- SimpleSimon
