2 speed fan switch terminals
ratwing
Post by ratwing »
The switch terminals (Intermotor 50091) aren't marked and all my searching only tells me that the one which isn't one of the 2 parallel terminals is 12 volts in - does anybody know which terminal is the low temp and which is the high temp?
Edit - I ended up having a play with hot water and it turns out that the 12 volts in terminal is as above, looking at the terminal side the left is the low temperature and the right is the high.
The low stays on too when the high switches on so both 'out' terminals are then live.
Return to “Cooling Area”
