I need a new clutch slave cylinder, the one I had was SD1, I know they make lots of different ones that fit land/range rovers, the old one was cast iron and some of the others available are alloy, I would like one in alloy but don't know which one will fit?
the reason for different types seem mostly to the inlet pipe thread type, I don't care about this as I can adapt to anything, any ideas ?
Clutch slave cylinder RV8
I'd second that
And once you know the bore I would contact Rally Design who I have always found to have a great stock of all sizes
I got this one in the end, alloy, but has a 7/16 inlet hole, just needed to buy the correct 7/16 fitting and make up a small joining pipe to my aeroquip hose. A SD1 cast iron one is £31, just because its got the right hole for a SD1 hose !
http://www.ebay.co.uk/itm/201291336018? ... EBIDX%3AIT
