What antifreeze ?
Devonrod
What antifreeze ?
Post by Devonrod »
What do you guys use in your RV8 ? I put new Blue in mine with distilled water and it attacked the water pump when stripped down after only a few months, turning the hose ends white, I have a copper/brass radiator and have read you cant use the red antifreeze as it attacks copper, any ideas.
I use blue in mine too mate,
50 50 mix
ged
Post by ged »
Me to. 50-50 mix with tap water. Cooling system when stripped looks brand new.
richardpope50
Post by richardpope50 »
You cannot use the pink because you have copper.
Could try www.evanscoolants.co.uk though.
Richard.
richardpope50
See this post and indeed my specific post with the response from Evans
http://forum.daxsportingclub.com/phpBB3 ... f=6&t=6030
Richard.
Re: What antifreeze ?
Devonrod wrote:What do you guys use in your RV8 ? I put new Blue in mine with distilled water and it attacked the water pump when stripped down after only a few months, turning the hose ends white, I have a copper/brass radiator and have read you cant use the red antifreeze as it attacks copper, any ideas.
What make of antifreeze was this? And how old?
You can't go by colour alone. The first antifreeze I remember was Smiths Bluecol and that was blue - hence the name. But not suitable for ally engines.
The one which was from the same company was green.
The usual active substance in one suitable for an RV8 cooling system with copper rad is mono ethylene glycol.
ged
Post by ged »
OK to be more specific this is what I use.
http://www.granvilleoil.com/product_inf ... rod_id=364
I've been using this for years & as I've already said my cooling system is spotless.
mike-b
Post by mike-b »
I am not particular what brand of antifreeze I use. However I always use a ethylene glycol based type. I never buy it ready mixed ( more expensive ) but mix it 50/50 with any branded drinking water or distilled - seems to work fine - cooling system always clean.
mike-b
Post by mike-b »
Sorry forgot to mention I run a RV8
Return to “Cooling Area”
