The spec i was told:
stage 3 DJE heads
5 angle seats,
throats opened out,
shortened and tapered guides,
spring platforms machined for the extra lift on the cam and skimmed for use with composite gaskets.
The combustion chambers volumes were matched and I think it had a 10.5:1 CR.
valves = wasted stem and had some mods to the back face.
now i have measured them and they appear to be stock sized valves. 40mm/34mm
ive attached some pics below, they have no steam seals fitted which will explain the oil consumption...
