Hi alll
I am new to this forum, and are planning to shoehorn a Rv8 into a suzuki SJ413 off-roader.
I have a 3,9 V8 and have started assembling a Volvo gearbox with a custom bellhousing., Here I have a little issue... Altough this becomes a short nice package, the clutch disc is a bit small under the rover pressureplate.
Have anyone here had the issue of needing a super short gearbox for their conversion? I really would appreciate some inputs on how to get around this problem.
Thank you
Shortest possible gearbox for the RV8
can't you just fit a bigger clutch disc to match the rover pressure plate? helix clutches or many other custom clutch makers will do you a rover diameter clutch disc with the Volvo splines to fit the input shaft?? it that won't work get a tilton multi plate 7 1/4 race clutch with the right splines on the discs, but that would be a tad overkill.
otherwise the shortest thing I know of is a shorty powerglide http://www.coanracing.com/Catalog.asp?CatClass=01TR 18" bell housing face to the end of the tail shaft, it is a 2 speed auto though.
best regards
best regards
If I am correct, on the SJ, the transfer box is 'remote', so a normal rear-wheel-drive transmission is what you want.
Have a look at the 4 speed transmissions from a Rover P5B or P6B. I don't know for sure, but I expect they are pretty short.
Only the P6 3500S had a 4 speed manual. And it's a pretty nasty box.ChrisJC wrote:If I am correct, on the SJ, the transfer box is 'remote', so a normal rear-wheel-drive transmission is what you want.
Indeed, but, I suspect it is the shortest box available, and having seen the rest of the drivetrain on a 'Zook', I doubt if it will be the weakest link....... Having spent a lifetime with Land Rover products, the Suzuki bits look like the sort of thing you would find in a Meccano set!DaveEFI wrote:Only the P6 3500S had a 4 speed manual. And it's a pretty nasty box.ChrisJC wrote:If I am correct, on the SJ, the transfer box is 'remote', so a normal rear-wheel-drive transmission is what you want.
