The ports in the head are 37mm-37.5mm in height and 23-24mm wide.The Gems intake is narrower at 21.8-22.5mm wide and 36.5-37.5mm high,so pretty close in height.
The thor intake however is a lot larger.The runners are 38.1mm as opposed to the Gems trumpets at 37.8 I.D,the ports are 24-25.5 width and 39.5-41mm high.
Quite a bit of mismatch there,the step would cause a lot of airflow disruption I would assume.Might explain the lack of top-end asociated with the thor manifold?
Doug
