Hi all
Anyone on here with a TVR Chimaera RV8 Pre Serp with a T5 gearbox who might be able to post a picture of the wires go into or indeed a wiring digram of the TVR speed signal box that lives under the dash and sends a signal to the ECU??
thanks
Ken
TVR Chimaera RV8 Pre Serp electrics q
Kensaunders1
Kensaunders1
And here's the picture of box in question now.. - but need help confirm identify of what each wire is please..
[/img]http://s1333.photobucket.com/user/kensa ... l.jpg.html
So I have 5 wires: are these correct...
1. Blue/Yellow = SIGNAL. (to speedo) (True Road Speed?)
2. Green = LIVE POWER. (from Ignition Live)
3. Black = Negative EARTH.
4. Grey = SENDER – to the speedo sensor
5. Green/Yellow = ECU – direct to ECU Pin No.6 – Is this the pick up for this is PIN 2 in white/clear 8 flat pin plug TVR engine wire harness?
