rv8 hilux
rv8 hilux
Hi guys. I have a hilux surf and a rover v8. I guess you can see where im going with this one. The rv8 has been fully rebuilt and ready for its new home. My only problem is i cant find any info about the gearbox. I want to keep the stock 5 speed manual box. Did you use a adaptor plate or special bellhousing. If any of you good chaps have done this swap how did you go about it. Any advice would be great
I have not done this engine swap but from memory of a couple of people on here who have there is an adaptor kit for Rv8 to hilux box, but it is made In either Australia or New Zealand where it is/was quite a common transplant. I think it would be a lot cheaper to make one yourself, the flywheel mounting to the rover crank may be a bit complicated but the worst case would be getting a new one made with Toyota ring-gear and pressure plate drilling and rover bolt pattern for the crank bolt holes.
best regards
best regards
The company in South Africa is Gilo Engineering, they do a bell housing and flywheel to Toyota gearbox (the Cressida W57...)
http://www.giloeng.com/
I had a quote last year to fit a W57 gearbox to my RV8 race car as that gearbox is 13kg lighter than the LT77, have not gone that route as yet
Maybe you can import a kit from them, they quoted me just under ZAR 5k so in British currency converted it would be around GBP280 excl importing
1986 Rover V8 3500SE m (Ex London Police Car)
1983 Rover V8 VandenPlas Historic Race car
1982 Rover SDS V8 manual
2013 Ford Focus 1.6 (daily driver)
