I've got a 4HA from a Scimitar SE6A which is 56" wide flange to flange. I want to fit this axle under my SD1 which needs an axle 62" wide. What I'm thinking is getting a cheap/scrap MGB axle as they're easier to source than Scimitar axles, and lengthen one of the axle tubes to make up the 62" total width. Obviously this will offset the diff but that would be beneficial for clearance and making it a bolt-on conversion into my SD1 with what I have in mind.
Does anyone have a spare 4HA axle that would suit me? Am I barking up the wrong tree and should find something else to do?
