Hi All
Needing a little help with a project I'm working on
I require a V8 SD1 rad but looking on Rimmer's site there are several types.
What is the diffference between the 2400TD rad and a manual non AC V8 rad (apart from the price difference?)
what is the difference between the various SD1 radiators?
The ATF cooler is merely a pipe loop inside both side tanks.
The AC rad has IIRC three rows rather than two to cope with the extra heat from the AC condenser in front of it. And fittings for two heat sensors (AC and cooling fan). But no extra brackets or whatever. The AC condenser is on brackets which fit to the body.
All the V8 rads have top hose connections on the nearside, bottom the offside. There are also one or two small hose connectors on the top offside, one for the expansion tank.
It's ok to use an auto rad with the cooler part unused.
I have a couple of spare EFI auto AC ones (the largest they do) which would need a re-core. You're welcome to one. Should be cheaper to have it done than Rimmer charge for one outright.
