cat removal dilemma
cat removal dilemma
Hi everyone
I have a 98 discovery v8 import with 50K on the clock. I use for on road and off.
I have had a misfire which seems to have blown a cat.
Sorted the misfire now. But not sure about the cats. Mot testing is not an issue.
The cats have two sensors per side.
Iwas thinking of removing the cats and senors and running the 470ohm tune resistor. But i dont want to increase fuel consumption. Can i remove cats and keep sensors and stay on same tune resistor.
I have been offered a seconhand pair of cats but i could have the cats removed for the same money and never have a problem again.
Engine is standard but the ecu is in a aluminium cast box certainly looks like it came out of the factory with it anyone else seen one of these. Is it maybe specific to the imports
The rear sensor is purely to measure cat efficiency.
Most cat delete jobbies only deal with this rear sensor
So front sensor operates as normal, engine should run as normal with no change to fuel use etc
Obviously factor in whether or not your vehicle needs cats to pass an MOT.
Typically any resistors or cheats are to make the rear reading acceptable to the ecufenton wrote:Cheers for that.
Are you meaning if I remove the cats that I should keep the front sensor and not change the tune resistor.
The fronts would operate as normal.
Talk of the tuning resistor suggests it's Lucas hotwire? If so, versions of that didn't use a cat. You only need a narrow band sensor when you have to keep the mixture at stoich. to avoid damage to the cat. With no cat, it could be run a lot weaker at cruise and improve the economy. And perhaps richer at full power to improve performance. But I dunno exactly what this would involve with the hotwire.
The serps may well all have had cats, but the same(ish) engine with the same(ish) injection on earlier ones didn't.fenton wrote:Yep lucas hotwire with serpentine belt 1998 model. Two very large cats two sensors each side one in front one behind cats. I thought all the serp 3.9 v8 had cats
Well the cats are coming off tomorrow and stainless pipe going in its place. I was going to ask them too keep the sensors in situ just in case they were ever needed.
I have already swapped the tune resistor for a potentiometer set to 470 ohms. Which should have selected the no cats fuel map. First thing I have noticed is that it's hunting on idle in park but I suppose that could be due to a partially blocked cat.
