rpi a&r power amps
landybob_v8
rpi a&r power amps
Post by landybob_v8 »
just got myself a couple off ebay
these are the dual timing ones for petrol and lpg
i dont use lpg so is it possible to wire it in and use it anyway???
i got the instructions with it but its all mostly about wiring for lpg
could i wrap up and secure the lpg loom from it and use the black and red wires alone for the loom to the dizzy
i dont fancy ringing rpi as i didnt buy them from them
v8's everywhere at least the one in the spare bedrooms gone now
mrs happy again
landybob_v8
nope dont worry ive since found out there single timing so im all set
mrs happy again
The Original Tom
Post by The Original Tom »
Just in case you still care :lol: , you can still use it with petrol alone, but your the position of the dizzy will always be about 10 dgs advanced to what you normally run.
Just blank off the blue wire asw that's triggered by the LPG solenoid.
Either that or connect the blue wire to the +12V on the coil and you're dizzy will always be in the correct position.
