I have Megajolted my P6 which is my daily drive - see here:
http://www.classicroverforum.net/viewto ... &start=105
I am running on an old map I used in the Landrover before, but it never really was 100% optimised.
I am trying to build a map based on the Rover figures, however the vacuum advance comes in from a ported connection and I am now using a true manifold pressure measurement.
Has anyone ever measured how the two compare to each other?
Rover figures state that for my dizzy 16 degrees of advance was added by vacuum starting at 3.5inHg and finishing at 15inHg. Google says this is between 10 and 50 kPa.
Obviously this had no effect at idle with the throttle closed, so do I just apply the 16 degrees additional in a linear fashion to the mech figures across the rev range and sort of blend it out around idle?
Jamie
Edit! Just realised I put this in wrong section!
