Wrapped block huggers, still need a starter shield?
3xpendable
Post by 3xpendable »
As per the title, when using block huggers and a std Rover V8 starter, do you still need to put a heat shield between the starter and exhaust if the manifolds are wrapped?
I am committed to the block hugger route, so no suggestions of "RV8 manifolds" please.
I did have the idea of fitting a standard 4 pot starter motor cover but then realised the exhausts are too close to get it on. Has anyone made a heat shield? I just don't fancy paying the wedge for one if I can make a suitable replacement.
1971 MGB GT (V8 project)
minorv8
Post by minorv8 »
How about Thermotec or similar that you can fit using tie wraos ? I have that on my starter.
JSF55
Post by JSF55 »
On my mates 302 we just wrapped the starter in some heat proof blanket with some stainless cable ties
So thats where it went !
3xpendable
Thanks all, I found some shield wrap and am going to try that to start with.
