Supercharger oil level monitoring
Currently re-building my Procharger centrifugal supercharger. I want to have an easier way to check the oil level from the self contained reservoir, currently a small dip stick but the process takes ages to take apart the front of my engine bay to gain access to the dip stick, a right pain and the first few miles with my rebuilt supercharger i'm going to be keeping an eagle eye on its oil level!
Thinking of either
1. using a couple of banjo bolts tapped into the case and linked with clear tube for a simple sight gauge,
or
2. some sort of electrical switch to light up an LED on my dash - this would only work with engine off - like an oil check light - as the oil will be in a mist during us. But I don't know if there is such an oil switch available? Could a conductive switch work? I presume oil conductivity is different to air? maybe could make up a little circuit to light up an LED if the resistance changes?
What do you think?
Blown v8
Post by Blown v8 »
Can't you just use a sight plug !
JSF55
Post by JSF55 »
Most modern engines have a low oil level sensor these days, could you not adapt one of those ?
So thats where it went !
Why dont you show some pictures of the problem you have with checking oil level ?
If it isnt leaking then it's full ?
Is there any room for a dip tube style sender ? You can get them as a thin rod these days, in almost any configuration you want.
Although obviously there is cost involved
Thanks for the suggestions,
Hadn't thought about a sight plug, had a look around the case but thing I may struggle to find a spot for it.
All of the oil level sensors i've seen from current new vehicles seem to be float types which I don't have room for.
There are basically 4 holes, two top and two bottom and depending on orientation can be either dip stick, of filler, or sump plug.
I could see leaking from the front pulley, but if it leaks internally I won't see this, and this is the seal i'm concerned about.
I have found an optical fluid level sensor - anyone familiar with these?
http://uk.farnell.com/jsp/search/browse ... s%3D202933
Instead of a sight plug! What about a sight tube?
I guess theres not much pressure in the casing. You can make a sight tube from all sorts of stuff.
Could you add some fittings to join a top and bottom tapping on the casing so they can be joined with a solid tube or even braided clear hose etc??
See here for an example
http://www.ebay.co.uk/itm/New-Homebrewi ... 460411d965
Return to “Forced Induction”
