So I bought myself a 4.4 RV8...
Vulture
Post by Vulture »
Good evening gents,
I have not been active in these forums for quite a while now. The reason is that my 3.9 RV8 broke down (again) and I just got a bit sick of it. So I put aside my SD1 in a shed and, after my girlfriend had nagged at me for 2-3 years to scrap the car, I broke up with her and took my Rover out again.
The engine went to my trusty machine shop to put a diagnosis on the problem it was having. Symptoms were loss of power and a valley gasket that was arched out by about an inch. Turned out that the pistons are too small for the bore. So I thought "Well, that sounds familiar" and went on searching what I had written on this board quite a few years back.
Vulture wrote: My guess is that the machine shop where I had the engine rebuilt and honed should have used oversize pistons but didn't.
http://www.v8forum.co.uk/forum/viewtopi ... sc&start=0
It is not the same shop where my engine is at the moment, by the way. :wink:
So my initial plan was to rebuild the 3.9er once more, with oversize pistons. But a 4.4 liter engine turned up on ebay last weekend and I just had to have it, so after a bit of haggling I bought it. Here's what I know about it:
- built by John Eales and run about 6000 miles in a Ford Escort, then stored away
- based on a 3.9 block (94 mm bore) with a reground "Iceberg" crank to give 80mm of stroke, for a total of 4441 ccm
- standard size Omega pistons with valve cut-outs, 10.25:1 CR (using a thicker composite gasket, according to seller)
- lightened and balanced, but otherwise standard, con rods
- stud girdle
I am planning to use the gear from my old 3.9 on it, that is:
- RPi Engineering Stage 3 Heads
- Piper 285 camshaft
- Weber/Edelbrock 500 carb
Additionally, I was going to buy Rhoads lifters, as the 285 cam is supposed to deliver power up to 6500 and the original lifters won't allow that kind of revs. Am I correct in assuming that the bottom end should be strong enough for these rpm ranges? It was previously fitted with a Crane 256 cam with solid lifters, which I think shifts the power curve up even further.
Would using a thinner head gasket (or two of them, even, one on the left bank and one on the right) give me a higher compression rate? Or is this too risky for the valves to hit the cylinders, despite the cut-outs?
My carb is currently fitted with the needles and jets suitable for the 3.9. Is it safe to install "as is" or should I change those? And if so, where do I start?
I was going to use my bog standard (though well-maintained) ignition. This is one of the components that I always plan on upgrading "later". Is it advisable to use the same plugs as on a standard Vitesse engine?
Any other thoughts/suggestions I might not have considered?
What happens when Pinocchio says: "My nose is about to grow!"?
