Welding a New Flange on Bellhousing
- topcatcustom
Hey, I have got to machine nearly 70mm off the front of my ZF bellhousing, and have done a drawing of the new flange I require to weld on to mate to the lump. Only question is- what thickness for the flange? It is a good couple of inches thick on the diameter, but plate thickness would 16mm be enough or safer to go with 20mm to eradicate chances of warping?
Any advice appreciated!
TC
Hi Tom
16mm would be plenty thick enough, how thick is the housing in that area? bet it is than 6 maybe 8 mm. My engine plate is 10mm and is about the same as the powerglide flange, and the engine plate is much better metal than the bell housing. OK your engine may be a little heavier than the chevy but even so 10 or 12mm should be plenty, 16mm if you must, my only worry using metal that thick would be getting a good even weld.
best regards
best regards
- topcatcustom
- topcatcustom
I don't think there will be much difference in heat in a big lump of ally Mike, it will take a while to warm up first whether it is 10mm or 16mm. If actual strength isn't an issue, I think I will go for 12mm then (cost for flange probably closer to £100 then!) , and clamp it to something big whilst welding.
Cheers guys.
Cheers guys.
TC
Re: Welding a New Flange on Bellhousing
I'm interested in this. Is it go get rid of the spacer used between drive plate and torque converter on the RR, etc? To make the box shorter for a RWD app?topcatcustom wrote:Hey, I have got to machine nearly 70mm off the front of my ZF bellhousing, and have done a drawing of the new flange I require to weld on to mate to the lump. Only question is- what thickness for the flange? It is a good couple of inches thick on the diameter, but plate thickness would 16mm be enough or safer to go with 20mm to eradicate chances of warping?
- topcatcustom
I used 12mm ali on the back of my bellhousing but skimmed it flat and machined all the holes and profile after welding.
It did distort a bit with all the heat involved.
It is welded inside and out to make sure of strength.
Edit to add I didn't do the welding
This guy in Clacton sorted it for me
https://www.facebook.com/RedTorchWelding
- topcatcustom
Getting it on centre is tricky.
I used the dowel holes on the engine side as a reference point and machined the big diameter in the centre first.
I then bolted the bellhousing to the engine and mounted a mag base and dial test indicator on the flywheel to check the bellhousing reference diameter for run out.
It did need tweeking to get it spot on.
- topcatcustom
I've had the flange cut with "crosshairs" included, and enough room to drill a pre centred hole in the middle to at least an inch, I plan to drill and ream this to a snug fit over the gearbox input shaft, which should hold it perfectly inline, the rotate is not as important, within a couple of degrees should be fine. I'm hoping this is a pretty fool proof plan!! I need to cut a couple of inches off the front so the input shaft should just be long enough to centre it up.
TC
