Single measurement required please!!
topcatcustom
Post by topcatcustom »
Hi guys, has anyone got a block with the crank in at the moment, I really need the measurement of back bellhousing face to crank flange, i.e. a straight edge put across and measured down to the flange where the flywheel bolts on, not super accurate!
TC
I measure it at 6.35mm or 1/4"
This is a 4.0litre Range Rover P38 engine.
topcatcustom
Bugger is that it?! I've got to make an adapter plate which will add depth, and the dimension on my engine is already 65mm.....
Thanks for the help Chris, got some real head scratching to do now!
TC
Return to “General Chat Area”
