Fuel coming out of a pipe on my su carb
- SimpleSimon
DEVONMAN wrote:The float needle is stuck or dirty.
Try gently tapping the base of the carb with a timber mallet.
If this does not work then you will need to remove the carb and check the float needle.
Denis
