HAYNES MANUAL - THE REAL MEANINGS
Haynes: Rotate anticlockwise.
Translation: Clamp with molegrips (adjustable wrench) then beat repeatedly with hammer anticlockwise. You do know which way is anticlockwise, don't you?
Haynes: Should remove easily.
Translation: Will be corroded into place ... clamp with adjustable wrench then beat repeatedly with a hammer.
Haynes: Remove small retaining clip.
Translation: Take off 15 years of stubborn crud, it's there somewhere.
Haynes: This is a snug fit.
Translation: You will skin your knuckles! ... Clamp with adjustable wrench then beat repeatedly with hammer.
Haynes: This is a tight fit.
Translation: Not a hope in hell matey! ... Clamp with adjustable wrench then beat repeatedly with hammer.
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read through before you start, now you are looking at scarey photos of the inside of a gearbox.
Haynes: Locate ...
Translation: This photo of a hex nut is the only clue we're giving you.
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy a tin of WD40 (catering size).
Haynes: Ease ...
Translation: Apply superhuman strength to ...
Haynes: Retain tiny spring...
Translation: "Jeez what was that, it nearly had my eye out"!
Haynes: Press and rotate to remove bulb...
Translation: OK - that's the glass bit off, now fetch some good pliers to dig out the bayonet part and remaining glass shards.
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your forehead are throbbing then re-check the manual because what you are doing now cannot be considered "lightly".
Haynes: Weekly checks...
Translation: If it isn't broken don't fix it!
Haynes: Routine maintenance...
Translation: If it isn't broken... it's about to be!
Haynes: One spanner rating (simple).
Translation: Your Mum could do this... so how did you manage to botch it up?
Haynes: Two spanner rating.
Translation: Now you may think that you can do this because two is a low, tiny, ikkle number... but you also thought that the wiring diagram was a map of the Tokyo underground (in fact that would have been more use to you).
Haynes: Three spanner rating (intermediate).
Translation: Make sure you won't need your car for a couple of days and that your AA cover includes Home Start.
Translation: But Novas are easy to maintain right... right? So you think three Nova spanners has got to be like a 'regular car' two spanner job.
Haynes: Four spanner rating.
Translation: You are seriously considering this aren't you, you pleb!
Haynes: Five spanner rating (expert).
Translation: OK - but don't expect us to ride it afterwards!!!
Translation #2: Don't ever carry your loved ones in it again and don't mention it to your insurance company.
Haynes: If not, you can fabricate your own special tool like this...
Translation: Hahahahahahahahahahahahahahahahahahahahahahaha!!!!
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on, swear at, throw at the garage wall, then search for it in the dark corner of the garage whilst muttering "bugger" repeatedly under your breath.
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are looking at, then declare in a loud knowing voice to your wife "Yep, as I thought, it's going to need a new one"!
Haynes: Carefully...
Translation: You are about to cut yourself!
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark plugs removed.
Translation: However, starting the engine afterwards will be much harder. Once that sinking feeling in the pit of your stomach has subsided, you can start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: But you swear in different places.
Haynes: Locate securing bolt.
Translation: Remember that worrying noise when you drove along the A38 last summer? That's where you'll find the securing bolt.
Haynes: Prise away plastic locating pegs...
Translation: Snap off...
Haynes: Remove drum retaining pin.
Translation: Break every screwdriver in your box.
Haynes: Using a suitable drift or pin-punch...
Translation: The biggest nail in your tool box isn't a suitable drift!
Haynes: Everyday toolkit
Translation: Ensure you have an RAC Card & Mobile Phone
Haynes: Apply moderate heat...
Translation: Placing your mouth near it and huffing isn't moderate heat.
Translation #2: Heat up until glowing red, if it still doesn't come undone use a hacksaw.
Translation #3: Unless you have a blast furnace, don't bother. Clamp with adjustable wrench then beat repeatedly with hammer.
Haynes: Index
Translation: List of all the things in the book bar the thing you want to do!
Haynes: Remove oil filter using an oil filter chain wrench or length of bicycle chain.
Translation: Stick a screwdriver through it and beat handle repeatedly with a hammer.
Haynes: Grease well before refitting.
Translation: Spend an hour searching for your tub of grease before chancing upon a bottle of washing-up liquid (dish soap). Wipe some congealed washing up liquid from the dispenser nozzle and use that since it's got a similar texture and will probably get you to Halfords to buy some Castrol grease.
Haynes: See illustration for details
Translation: None of the illustrations notes will match the pictured exploded, numbered parts. The unit illustrated is from a previous or variant model. The actual location of the unit is never given.
Haynes: Drain off all fluids before removing cap.
Translation: Visit bathroom, spit on ground, remove baseball cap in order to scratch head in perplexity.
Haynes: Top up fluids.
Translation: Drink 2 cans of beer and call out a mobile mechanic to undo the damage.
THE CONDENSED HAYNES MANUAL
All makes and models post-2000
For a modern car chock full of electronics, all that's in the Haynes Manual is:
Routine Service: Take it to a main dealer and hand over a large amount of cash.
Advanced Service: Open the bonnet. Decide all that stuff is far too scary. Proceed with routine service (see above).
Haynes manuals explained...
Jump to
- Gold Members & Sponsors
- Admin Only
- *** Forum Sponsors & Members Discounts***
- ↳ Discounts Offered To Forum Members
- ↳ Graham Sykes Insurance
- ↳ V8performanceparts.co.uk
- ↳ extraefi.co.uk
- ↳ Formula Power Leads
- ↳ Adrian Flux Insurance
- Gold Members Private Section
- The Forum Members
- ↳ Please Tell Us About Yourself
- ↳ Members Pictures Only,
- ↳ V8 Members On FaceBook
- ↳ The V8 Owners Forum On Facebook
- ↳ Jokes
- Rover V8 Drag Racing Series??
- ↳ Rover V8 Drag Racing.
- Competition Area
- Insurance Advice
- Cars & Engines *** V8 ONLY ***
- ↳ Body & Strengthening
- ↳ Brakes & Suspension Area
- ↳ Cooling Area
- ↳ Drivetrain & Transmission Area
- ↳ Electrical & Ignition Area
- ↳ Engines Area
- ↳ Exhaust, Cylinder Heads, Fuel And Intake Area
- ↳ Forced Induction
- ↳ LPG Section
- ↳ Nitrous Oxide Area
- ↳ Steering Area
- ↳ Your Cars
- Forum Related Information
- ↳ Area For Testing Only (please do not start topics)
- ↳ Forum Rules For V8 Owners Forum
- ↳ Forum Donations And Gold Membership
- ↳ Forum Faults
- ↳ Forum Advertising/Sponsors Required
- ↳ Latest Forum News
- ↳ Forum Merchandise
- General Chat *** V8 ONLY ***
- ↳ Your Garage Scene
- ↳ General Chat Area
- ↳ Engine Swaps And Conversions Area
- ↳ Magazine Features Of Members Car's
- ↳ Your Car Video's
- ↳ Events
- Classifieds
- ↳ For Sale
- ↳ Wanted
- ↳ Parts Transportation/Collection Service
- Performance Area *** V8 ONLY ***
- ↳ 0-60 Results
- ↳ 1/4 Mile Times
- ↳ Rolling Roads And Dyno's
- Handy Links - To Be Listed Here Contact Coops:
- ↳ Capriracing Capri Site
- ↳ V8 Developments
- ↳ RealSteel
- ↳ V8 Tuner
- ↳ Capri Technical Forum
- ↳ Shakespeare County Raceway
- ↳ Santa Pod Raceway
- ↳ Noswizard.com (Nitrous Oxide)
- ↳ SC Power
- ↳ JRV8
- ↳ ms2tuning.com
- ↳ Bailey Performance Ltd
- ↳ Bailey Performance On Facebook Too .....
