Hi all ... yet again,
I intend to fit a 16-inch electric fan fully shrouded this time and I am looking for a little more space between rad & pump. As I will not be using a fixed fan any longer ( P6 pump is fixed fan ) I could do with another 20mm better still 30mm. The pump has its pulley bolted to it and will remain in place, however does anyone know if the nose of the pump at the front can be cut off some 20 - 30 mm? Perhaps it could be heated and pulled off altogether?
I want to fit the new electric fan central if possible, I realize fitting it off centre will make little difference but then central fitting will make life a whole lot easier when it comes to fitting with the shroud in place.
Many thanks, mike ( yet again )
Rover P6 PUMP CUTTING
I am pretty sure from older threads on here that you can shorten the P6 pully by atleast 10 or 15mm by chopping it off with an angle grinder, cleaning up the pulley and re welding the pully on the shaft stub. I would Tig rather than anything else as it will put less heat into the front of the pump. . . . then you have to get the other pulleys to line up again.
