O2 Lambda Probes
V8RoverDave
O2 Lambda Probes
Post by V8RoverDave »
I'm in the process of fitting a Hotwire injection system to my 3.5 Rover V8 engine and intend to fit 2 Lambda probes into my exhaust downpipes.
I know they need to be the 3 wire Titania type, but the cheapest I can find is £80 each.
Does anyone know of a cheaper alternative, or a totally different make of car that have them fitted that will work with the Hotwire system?
Any help would be great.
Thanks,
I wonder if the hotwire actually reacts to different signals from the two sensors - or just averages them? I suspect the latter.
If so, you could fit a single wideband set - which will be useful if you ever change to MegaSquirt etc - and use the narrowband output. It could also give you a readout of the actual AFR at the same time.
Re: O2 Lambda Probes
V8RoverDave wrote:Hi,
Thanks,
Are you sure they are the expensive type ?
And Lambda sensors arent strictly speaking necessary
How old is your car - does it have or require CATs for the MOT?
If not why not change the tune resistor for a non-cat map and omit the lambdas completely.
Also I believe the hotwire lambdas are variable resistance not voltage -Therefore I'm not sure if you can use the narrowband emulation output on a wideband..
http://www.picoauto.com/applications/lambda-sensor.html
V8RoverDave
Thanks Chaps for your replies,
I hadn't thought about it averging the probe inputs, good point. But I'm not sure what you mean by wideband and narrowband?
I realise it could run without a probe but I thought the system would run better with the Lambda feedback.
The car doesn't have CATs, but again I was on the understanding that if it has a tune resistor then it will run a standard fuel map, which won't let the engine run as well and fuel consumption will be up. But again I'm not sure on this?
Thanks, Dave
V8RoverDave wrote:Thanks Chaps for your replies,
Thanks, Dave
Do you know what tune resistor (there's more than one) - a photo or measure it's resistance with a Digital meter
V8RoverDave
Hi Eliot, I wasn't looking to go down the tune resistor route, unless you think it won't make much difference to the running with one fitted.
