borgwarner type 65 gearbox
roger doger
How do I convert a borgwarner type 65 gearbox from a jaguar to fit a rover 3.5 v8 engine?
Re: borgwarner type 65 gearbox
Probably easier to just buy an SD1 box. And sell on the Jag one. Unless you already have the parts needed to convert it.roger doger wrote:How do I convert a borgwarner type 65 gearbox from a jaguar to fit a rover 3.5 v8 engine?
IMHO, if it's a standard 3.5 and for road use, the later GM SD1 box is miles better.
roger doger
Just change the bellhousing from the Jag one to a Rover one. The Jag converter will fit straight on to the Rover flexplate so doesn't need changing.roger doger wrote:How do I convert a borgwarner type 65 gearbox from a jaguar to fit a rover 3.5 v8 engine?
roger doger
Yes. Which is why I said you might have problems finding one on its own. Complete SD1 boxes are common enough and not that expensive. So I'm not quite clear why you want to convert a Jag one?roger doger wrote:hi,
Thanks for the info, is it a Rover autobox bellhousing that I need not a manual bellhousing (sorry to be so thick)?
