this is the transmission set up
these are the parts to connect the transfer case to the transmission before assembly & after
assembled
where it's located
early mockup of front diff assembly
this is the rodeo spindle I have to spread the suspension tubes by 8cm's to fit it between the ball joints
front xmember & mounts for rear diff it's 3.08 ratio LSD
this is the adapter's to bolt the kombi cv's to commodore diff
test fit I will have to space hub carriers out by 12mm to allow movement on shafts to stop binding
the rear diff sitting in to check location
tailshaft for front diff just has to have front section shortened & a flange put on in place of slip yoke
