The engine is in a TVR Griffith, originally it was a small journal, non x-bolted engine which has departed this earth (long story.....)
The current engine was built by V8D and is a 4.6, x-bolted, flanged liner block with standard 4.6 rods/pistons and Stage 3 heads. Running a Megasquirt 2 with EDIS8 it made 283bhp after tuning on the RR.
The reason for going to 5.0 is to put the car back to 'standard', i.e. back to a real 'Griffith 500', but without the original TVR 94mm bore and 90mm stroke (I'm not fan of this small journal crank - please don't ask.....
Is the following a 'good' option, or is there a better route:
1. Have the crank ground to 86.36mm Stroke, 2" big ends.
2. 96mm forged pistons
3. ??? Conrods - not sure on this one?
For the increase in bore, I'm assuming machining and new flanged liners required. Would it be better to sell the existing (94mm) flanged liner block and invest the money in a used block and the machining for 96mm flanged liners?
This is 'next years' winter project, this years is a JE crossover manifold.
Any opinions gladly received....
