distributer
daz 104
distributer
Post by daz 104 »
any one no which way the wires go on coil from dissy . did have a white one and a black and white one . but where it goes on plugs its differnt colours :evil:
This is one of the many setups:
daz 104
Post by daz 104 »
great that you . :D just realised mine as 3 in a row plug has 2 wires
ramon alban
Post by ramon alban »
Hello Daz, Your amplifier, would normally have 5 connections.
Two go inside the distributor to connect to the pickup coil
One is the earth via the bolt holes into the body of the distributor.
The White/Black wire goes to Coil Negative.
The White wire picks up its 12 volt supply from the ignition switch via coil positive.
You may, at some time, wish to study the typical V8 electronic ignition system written in laymans terms for the home enthusiast?
http://www.vintagemodelairplane.com/pag ... ion04.html
http://www.vintagemodelairplane.com/pag ... ion05.html
Hope this help? Good Luck!
daz 104
Post by daz 104 »
thank you thats great . :D i didnt want to get it wronge way and kill it lol :(
