just looking tap into other peoples v8 knowledge to see if anyone has had similar experience of a 4cu rover 3500 intermittently running badly and what caused that
the intermittent problem is limited to idle speed and small cruise throttle openings ie up to 45mph (snatchs and jerks really quite violently @ 30mph) , above 50 the roughness isnt felt unacceptably badly but i notice the vac gauge shows it needs 5in/hg more to maintain the cruise speed than when its running normaly at most cruise speeds
when i come to a stop and allow it to idle it starts to hunt up and down (400-900rpm) in a pulsing sine wave idle (at around maybe 0.75hertz ish) and will normally stall despite the idle screw and co setting being correct(vacuum rises and falls in time)
usually after 40mins driving the engine will inexplicably chime into normal running and idle properly
the engine is in a triumph dolomite,,but the installation is all as stock
overrun vac cuttoff has been bypassed
3 ecus all do the same thing (some make the engine feel less responsive but i guess thats variable mapping)
throttle over 10% is strong and smooth
cold running is smooth as silk (fast idle 1100rpm)
3 dizzys didnt affect it,,opus one,,the latest one and a points dizzy
fuel pressure is good and constant
not sure if the air flow meter could be the cause, or a temp sender having a duff reading at certain temp ranges
ive also tried a 14cux system but had if anything much less success running wise massively lean,,and its idle valve created a slowly hunting idle
anyones opinions and tips as to fixing the efi,,or alternative fueling will be greatly valued so i can hopefully drive around enjoying 8 cylinder flexibility rather than it being akin to a lister single diesel in a washing machine
Ron
