3.9 interim block -v- 3.9 normal block pistons
task
Post by task »
I'm building an engine for a MGB GT.
I have a 3.9 block from a 1996 Discovery, it's an interim block but is missing a piston/rod.
I also have a 3.9 from a 1993 Range Rover that was apparently run with low oil pressure but has a complete set of pistons. I haven't stripped the engine yet so haven't seen what damage there is, if any.
Are the pistons the same?
I had planned to get the interim block honed and fit the pistons from the earlier engine with some new rings.
Open to other suggestions though :)
1991 CSK Range Rover - 4.6 Stage 3
1998 Discovery 3.9
1979 MGB GT - V8 conversion
POAH
Post by POAH »
pistons are the same AFAIK
3xpendable
Post by 3xpendable »
Hi task,
I'm doing the same as you, and having recently bought an interim 3.9 i've ben doing some research. The only difference is the crank driven oil pump means the crank has a longer pulley keyway, and the minor differences in the block. The main bearing caps are slightly different in shape too but this doesn't affect the pistons
Any chance of some pics of your conversion?
1971 MGB GT (V8 project)
spend
Post by spend »
For 3.9's there are 5 piston/block bore grades:
std = nom size to + .0075mm
A = .0075 - .0150
B = .0150 - .0225
C = .0225 - .0300
D = .0300 - .0375
(Grades should be shown on crown & block face)
I think this is why there is occasionally confusion over the different specs used for the RV8 bore - 3.7" (93.98mm) or 3.7015" (94.02mm), hence you frequently see the simple median of 94mm used.
task
Post by task »
spend wrote:For 3.9's there are 5 piston/block bore grades:
A = .0075 - .0150
B = .0150 - .0225
C = .0225 - .0300
D = .0300 - .0375
How are these identified on the pistons themselves?
I've stripped both engined down and found the following markings on the pistons themselves;
Early Engine;
AM413
758404
Hepolite
22059
AE HRC1828
The top of the piston has a "dimple" in it and is marked with an L
Late Engine;
413P
758414
AE HRC 1828
22059A
the top of the piston has the following marks 22059 Z07 M6 MY
I have 7 of the later pistons and 8 of the early ones.
Assuming the pistons are usable I would fit them to the later block. The crank that goes with these pistons looks good to so I would consider using this also, depending on which front cover I use. I'm limited to space with the MGB and I believe I can only use a SD1 or P6 front cover and pulleys, which seem hard to find.
1998 Discovery 3.9
