Rear axle ,
ford100ev8
Rear axle ,
Just starting work on my ford 100e , I need a rear axle that is 30 inch in total and can take 500 hp , any Idears , will a ford 8 inch go that narrow , thanks
Yep a 8" will go that narrow, might need to re tube it as most 8" have stepped tubes, Aftermarket shafts would be needed, either Hausers or Robinson Race cars can supply custom spec shafts. Personally i would think a 8" would be marginal with 500hp, especia;;y if you are running either slicke or big MTs, what engine are you using to develop 500hp, ??
ford100ev8
Yep, I would go 9" the only way your HP will go is up, start with strong foundations, a 9"would probably work out cheaper in the long run, other than strength, the availability of off the shelf shafts, the choice of ratios is about the best you are going to find, sometimes worth buying one new from the states can work out cheaper, and get it built to your spec from the outset, http://www.currieenterprises.com/
