Rocker tubes V springs
Hi guys, I've acquired a Myford 7 lathe and need to use it for something! I was thinking about making some tubes to replace the rocker shaft springs and was wondering what are the actual benefits of going for tubes over springs. Any thoughts?
Some spring is still needed even with solid spacer tubes IMHO, all you are doing is to try & remove the gross lateral movement that the original springs require, but I think you still need to consider:
- Thermal expansion
- Trying to keep rocker arm sideways movement limited
- Friction on the sides of the rocker arm
- Oiling - ie how much is allowed to escape out of the bush.
My solution was to make spacers and then assemble like rocker - shim - spring washer - shim - spacer. I used ally tube but have seen some done with copper plumbing pipe (eek).
ETA Note: I found that using this method there was no need to restrict the oil flow up into the rocker shafts (with roller rockers) as the shims & springs helped retain oil pressure in the rocker bushings, even when using additional oiling up the pushrods into the rocker arms.
- Thermal expansion
Hi Dave,
Thanks for your reply, I'll bear in mind your comments.
I guess tubes will allow less oil to bleed out of the rockers than what the springs do although the clearance gap and wavy washers must give a pretty
easy escape route for the oil.
I'm still wondering what the advantage of going to tubes is, if indeed there is any advantage. maybe there is just a bit less friction in the rocker gear with tubes.
Pete
Pete
Flying Phil
- Helpful or Confused
I used them in a 1293S engine but I thought it was because of the high revs.Flying Phil wrote:Hi Pete
I've used tubes on my Rover V8's and "A" series engines. There is a minute! reduction in friction. There are no expansion problems as the heads expand more than the rocker shaft assemblies because the heads run at a higher temp.
A GOOD additive would provide better friction reduction imho (I use ZX1),
