Lets talk carbs
3xpendable
Lets talk carbs
Post by 3xpendable »
For the 3.9 Rover V8 I plan to fit in my engine bay whats best? I had intended to use a Holley 390 4 barrel but i've heard the Weber 500 is much better for mild and fast road use.
Arguments for each below please...:)
1971 MGB GT (V8 project)
SU's pretty good too!
kev_the_mole
Post by kev_the_mole »
IMHO quad Webers. One choke per cylinder seemples :D
Webcon now do my setup for the RV8
Flying Phil
Post by Flying Phil »
Or go quad IDFs but you need a bigger scoop!Image[/img]
Flying Phil
If it has to be carbs then either Phil's or Ian's carb porn is going to be best by far, the webber carbs are vastly more tunable than the 4 barrels and far better made, trouble is that is reflected in the price. For anything below a genuine 210 bhp on a 3.9 then SUs on a prepped and correctly matched standard manifold will give the best results for a given price (provided the SUs are in good condition). Otherwise a standard injection manifold and an aftermarket ECU will beat any 4 barrel hands down on performance fuel economy and price.
Flying Phil
I actually will be selling the 4 X 36 IDFs as I now have 4 x 40 IDFs...... You could also try a twin 38 DGAS set up on an aluminium Hi- Rise manifoldImage[/img]
Flying Phil
