Advice needed on lossening Crank Pulley Bolt
ok so im rebuilding the 4.6 gems before i fit it in the 90 and have 99% of the engine stripped but just cant get past this crankshaft pulley bolt.
as its a project i dont have all the parts yet, so dont have a flywheel to help me stop the crank turning.
i really cant think of a way to stop it.
all advice greatfully received.........
- topcatcustom
I have a 12v impact wrench bought from Maplin for about 30 quid. It's quite large - about the size of an old mains electric drill. Sold as a wheel nut remover. It spins up to speed, then whacks the nut in a rotary way. Made light work of my crank pulley bolt, without trying to lock the engine. I also used it to undo the head bolts. Says it produces 250 ft.lb of torque.
Think you can get them on Ebay.
Iv got a pretty good air one and a large cordless clarke which is pretty powerful but today they wouldnt shift the bolt.
I was thinking maybe i could remove the sump and wedge a piece of 4x2 between the crank an block to stop the crank turning. Would this be ok?
The engine is on the floor so isnt the easiest of things to work with.
timber wedged in the crank is ok, but make sure you are not resting against a rod.
Before you give it a hard time with a windy, A good heavy, sharp blow on the bolt head, then, get a BIG breaker bar, and tighten the bolt!!!, then try to undo it, you may be surprised
- topcatcustom
first job before removing the engine ( if its in there to start with ) is too put a breaker bar on the nut and crank the starter ...
does the job a treat
even if the engine is out fit a starter motor and hold the nut ...its becasue the starter ring gives you a really LOW gear ratio compared to the pulley nut
