Injectors
Injectors
Just bought a twin plenum set up to use on my Twin Turbo'd TVr motor, a quick question, are all injectors for the RV8 and it's derivatives the same? Are 5.0 ltr TVR ones the same as 4.6 RR? Are the 4.6RR the same as 3.5?
Brief spec, 4.0 ltr bottom end, Blower cam, JE big heads, 12 psi boost, looking for around 400 hp, NoS, if the stock injectors won't do, what are the best ones to get?
Jeff
Jeff
- daxtojeiro
- Forum Sponsor
Hi Jeff,
Im afraid the original injectors wont be able to fuel that power, you will need around 36LB or bigger. I fitted 500cc injectors to fuel to around 450BHP, and these are near the limit,
Phil
Phil
Hi Phil,
Thanks for the reply, I'm under the impression that the twin plenum manifold has different injectors in than a hotwire manifold.
The flapper type are imperial and the hotwire are metric? Can anyone confirm this?
Can I use a P38 or disco inlet manifold and fit the twin plenum to the top of it?
Any help would be greatly appreciated
Jeff
Jeff
I have just done this myself, so have the answers 4 u.
I had the jag injectors which are 227cc in my twin plenum on a 5.0ltr tvr motor, Phil said to me they would be maxed out so i got 30lb pound injectors which are different style as u pointed out, same as hotwire though.
The twin plenum inlet manifold as bigger ports by 3mm so i wanted to keep this so adapting the manifold to take later style injectors was the answer.
U need a 14mm drill bit, drill out the manifold from the existing size to 14mm but dont break thru the end, it will break thru almost, look at the later hotwire manifold and try drill it as far as that. U will c what i mean when u do it,its hard to explain, it leaves a shroud over the side of the injector.
The fuel rail from the hotwire bolts on the same but fouls the temp sensor, as im running megasquirt i dont need the thermotime sensor so removed this and put coolant sensor in there with an adaptor because its smaller thread size.
Hope this helps.
Hope this helps.
- SimpleSimon
Thanks guys, that's the answers I was looking for.
So I need to open out the manifold to accept the later hot wire injectors and use the hotwire fuel rail too. I'll be using either a megasquirt or a Motec ecu, all to do with price tho.
So 30lb injectors should suffice although if I'm going up in size I'm tempted to buy bigger ones so that I only have to buy them the once.
I read somewhere that SVO ford green injectors are supposed to be good, I'll have to go and do some research.
NO, the colour does not generically denote anything.Fozwanger wrote:Are the green injectors used on v6 st mundano's the same as 5.0 stang ones? I take it the colour donates the flow rate and apart from that, injectors are injectors?
And whilst injectors are all injectors in as much as they inject fuel, yes. But there are various kinds, they have varying spray patterns etc.
But that's getting into the realms of magic to know what spray pattern is best
Generally unless there is a very good reason to select a specific spray pattern, just buy ones that are known to work and are cheap.
It's very unlikely the green Ford items ( Bosch ) used on the US cars are the same ones as the Mondeo.
