guys, just got the fuel system primed on the truck, pressure comes up to 5-6psi, but for some reason one of the primaries is dripping fuel in to the chamber, and also there is fuel leaking from between the carb and the inlet manifold for some reason and can't figure out why!!
going to take it off tomoz for a proper inspection, but any sujestions on what it could be?? carb hasn't been used for a fair bit of time, so could it be things just settleing back in?
jono
Holley 390 help...
Boosted LS1
Fuel level may be set to high. The float can be raised or lowered. Remove the plug on the side of the float bowl. The level should be set to the bottom of the hole, ie fuel shouldn't dribble out of the carb through the sight plug hole.
Eta, if it worked fine before then I'll second the 'tapping' suggestion to free a stuck needle.
