14 CUX Software
jimbob
14 CUX Software
Post by jimbob »
As the title says, is there any software on the market that you can use to check the readings & sensors on the 14 CUX. I know theres test book etc.
Just looking for a cheap solution.
Jim
SimpleSimon
Post by SimpleSimon »
Here you go http://www.g33.co.uk/fuel_injection.htm Very knowledgeable guy 8-)
Re: 14 CUX Software
jimbob wrote:As the title says, is there any software on the market that you can use to check the readings & sensors on the 14 CUX. I know theres test book etc.
Jim
Pretty well all the sensors can be checked with a DVM.
Somebody has written a piece of software for the 14CUX now:
http://www.pistonheads.com/gassing/topi ... the++14CUX
jimbob
Post by jimbob »
Thanks Gents, yep i've gone through all me#y sensors with the AVO a couple of weeks ago.
Needed something that could log while i was on a test drive, just have a slight hesitation around 2100 rpm, hopefully this will help in tracing the problem, before I start spending cash on parts that really don't need to be changed. All plugs look clean, hopefully its a HT lead.
Will take a look at the Rover Gauge
Does the 14 CUX store fault codes for everything? I'd be surprised if it does.
jimbob
Post by jimbob »
No i don't think it does, I'd like to know what band i.e. + or - the sensor has before it says its open circuit, hence the rover gauge will log the readings on a test drive, with my lap top hooked up.
Just sent two MAF's off for repair to a company in Nottingham.
Just been searching the throttle pot prices and nearly fell of the chair, nearly 200 squids.
jimbob wrote:No i don't think it does, I'd like to know what band i.e. + or - the sensor has before it says its open circuit, hence the rover gauge will log the readings on a test drive, with my lap top hooked up.
It's perhaps the main reason I converted my flapper SD1 to MegaSquirt. As they age, things like the TPS and flapper wear out - and any remaining new ones shoot up in price. MS software allows pretty well any sensor to be substituted. Same with the injectors.
blitzracing
Post by blitzracing »
The RoverGauge free software will give all error codes the ECU generates and stores, all sensor data, fuel map info, long and short fuel trim values, (for those with lambda's ) stepper position and control, fuel pump control, a data logging facility for live sensor data, and a Eprom copy facility. Not such a backward ECU as people think! Discussed here:
