Search Issues
Search Issues
Hi Tony
Just wondered if you experiance this message as I seem to get it quite often
"You cannot make another search so soon after your last; please try again in a short while."
I get it when trying to view messages since last logon. Was wondering what the time limit is between checking for new messages.
Wondering if I have a browser issue
regards
Reg
regards
Reg
I've had this many times in the last 3 weeks. Even when flitting between threads. It stops me looking at anything so I just log off and come back later. Sometimes it happens all day. Which is why I disappear for a day sometimes
Only started happening 3 weeks ago though???
Bizarre, it really makes no sense. That message is the "flood" one Reg, which isn't even turned on, supposedly. The code hasn't changed in donkeys so I'm puzzled by the cause, and therefore lost what to try and do at the mo..
Chuck me a test PM, I'll try replying. It may take a day or three, mental weekend of work on, but will get back to you.
Anyone else seen similar? Need to know what you were doing and what the message said as exact as poss.
Perry are you seeing this wording-
"You cannot make another post so soon after your last; please try again in a short while."
Hi Reg,
Email's outside of our control byond creating the message and pinging it out, once it leaves here anything and everything can happen on it's merry way across the net. Esp with the freebies like Hotmail and Yahoo. Gmail is a bit of a tart, bit less fussy/troublesome.
If I have a brainwave (highly unlikely) re the flood message I'll post back.
btw anything counts towards a "flood", sending a PM and making a post - but then the thing is supposed to be turned off...
Bill
Bill
Ha Ha!!r2d2hp wrote:Hi Perry,
Will try and reply to you tomorrow then.
regards
Reg
Maybe see you Sunday for a cuppa Reg ??
Pel
Just tried this to death with the posts since last visit and I cant get the same error message either by opening links in a new tab or by going to the link in the same tab and using the back button. I can go through them instantly without any problem.
What I cant do though is do a normal search at all, I only ever get the the same error message as you. Looked in the admin section but there isn't any settings for this so it must be either in the code or a setup file somewhere.
