Does anyone know the thread sizes for the thermotime switch and coolant sensors on the flapper manifold? I'm guessing it will be a NPT, i need to get an adaptor to fit the coolant sensor in where the thermotime switch went as with the hotwire fuel rail on the flapper manifold it sit above the position of where the coolant sensor goes. Also can anyone verify that the ms air sensor is 3/8 NPT and where can i get a nut to weld into my intake pipe which is stainless steel.
cheers Paul
coolant sensor thread size.
