see picture and Spec.
3.9l v8
Compression ratio 9.35:1
Heads Skimmed 1mm and Ported
Valve Guides Shorteneted
Valve Backs Machined for narrow Seats
Piper Vernier Timing set
MGBV8 Oil Pump Spring
New Cam bearings
New Mains and Big end bearings
ARP ROd Bolts
Oil Gallery Restrictors for rockers in block
TVR Griffith Cam, followers and Clutch
Double Valve Springs + crane retainers
Offenhauser Manifold
Holley 390 Vac Secondary
I am having a problem with the motor not wanting to rev much past 4k
I think the main cause of this is the fuel pump which is facet 574a and looking at the details it's to about 4psi. prior to the engine replace I had no problems with it. but then it was feeding twin SUs on a 3.5 V8.
I have been informed to go get a red top holley pump to solve this issue. but wondered what other recommendations anyone suggests. I was told a red top should not need a regulator either (where as blue top does).
Any suggestions and advice welcome
Lushman
