SD1 VDP EFI rear springs colour code.
Has anyone got a set of these lying around and can check the colour code? Just to be clear, there are a variety of different rear springs fitted to the various models, and the VDP EFI is 'standard' height with progressive rate rear springs and Nivomats as standard. The factory fiche is clearly wrong about this model, as it was the last variant produced and may not have been updated properly.
It is a quite a popular axle for some projects as it has the tallest final drive ratio of all SD1s, shared with only the auto Vitesse. But obviously different suspension.
