I am slowly getting all the niggling things sorted.
You fix one and another rears it's head.
I am running no lambdas and the green tune resister
Timing spot on
Stepper cleaned and viewed moving in and out
stepper well sealed to housing
Stepper connector on
Vacumn pipe connected to regulator + no splits
Rubber pipe to plenum fitted + no leaks
Car starts ok, idles cleanly at 900 rpm when stone cold and revs then gradually rise to 1600 rpm.
The air screw on the plenum is screwed down all the way, if not the more you unscrew it, the higher the revs!
Funny thing is that when the idle was normal and it started from cold, it always ran very rich till it warmed.
Now it runs cleanly from cold and when warm, idling at 1500 rpm shows 12.3 or thereabouts on the fuel ratio gauge.
Suggests huge air leak/AFM/Gerbills???
I've run out of ideas and look to you guys for an answer............
