Rover V8 rocker shaft clearance..is this okay ?
smoker
Post by smoker »
I recently bought a set of Rover V8 rocker arms and shafts for my SD1. I noticed there seems to be quite a bit of play between the shaft and rockers so I measured them...
Shaft is 20.53mm
Bore of rocker is 20.65mm
I make that a clearance of 0.12mm which seems too much. Similar engines I have looked at advise up to 0.05 is acceptable but |I can't find and specs for the V8. The supplier says that they checked with Land |Rover and the parts are fine hmm. Has anyone got the official specifications for the rockers i can't find them in any service information I have looked at.
I really need to get rid of the dreaded clacking noise so I really don't want to fit these parts if they are out of spec
Thanks all
1984 Rover 3500 running on lpg
SimpleSimon
Post by SimpleSimon »
This seems to be a problem with some aftermarket rocker arms (quality control) more so than the rocker shafts if memory serves, I know V8D have seen this problem amongst a few owners in the TVR RV8 community :( good s/hand OE parts seems the solution at the moment. 8-)
Quagmire
Post by Quagmire »
I had some that were the same when i put my 3.5 together, in the end I fitted a set of used (but good) rover ones. They had much tighter clearances even after they had done whatever mileage they had on them!
1974 Rover 3500s
1984 3.5 90
1959 2.25 series 2
smoker
Post by smoker »
Thanks for the replies :) i think I will send the parts back for a refund - it would be good to have the Leyland's spec for the tolerance on the shaft incase they wont accept if anyone has those :) .
The manufacturer says that the parts are within spec which i doubt with 0.12mm clearance..surely new parts shouldn't be sized to the upper specification of the tolerance :shock:
Have a look at this thread
http://www.v8forum.co.uk/forum/viewtopi ... c&start=15
I would say 0.12mm is too much. My worn OE rockers measured 0.09!
My new rockers measured 0.04mm clearance.
smoker
Post by smoker »
Thanks SuperV8 that's a most interesting thread.
I have returned my pattern rockers and shafts back now as they too had more clearance than the OE parts -(measuring across the least worn sections)
The low mileage Rover set I bought on ebay are about a million times better.
