LDV V8 4HP22 - any idea on the spacers/shims??
Mystery Machine
Post by Mystery Machine »
I picked up a 4HP22 today from Trev (many thanks Dude, it was great to meet you :D ) and it comes complete with all the spacers & shims needed to fit it to the V8 block.
I haven't had chance to have a really close look yet, and hope it'll all make sense once it's all laid out (currently a box of metal bits) but does anybody know roughly what order everything fits with regards to the spacers/shims?
I'll post a photo up in a minute if that helps anyone, but if someone has an idea of what goes where, I'd be VERY grateful because it'll probably save me a lot of time trying things in different orders/places.
Many thanks,
Bruce.
Mystery Machine
Here is a photo I've just taken of the various parts. If anyone has any idea what goes where I'd be VERY grateful. :D
Obviously there is the flex plate on the top left then working clockwise from there:
(1) Large adaptor plate/shim that looks like it bolts between the flex plate and torque converter
(2) THICK spacer with a small shaft on one side
(3) Small shim
(4) Spacer/adapter
(5) Medium shiim
(LINK to bigger photo)
If anyone has any ideas on this it'll probably save me a lot of time messing around trying out different combos.
Many thanks,
Bruce.
JSF55
Post by JSF55 »
In this order 3 then 4 with the correct small cap head bolts, then flex plate- 2- 1-5 have some long 3/8? bolts going through them :) john
So thats where it went !
Mystery Machine
Many thanks John,
I think that's going to save me a good few hours of playing around with it all in different combinations.
I'll let you know how I get on?
Bruce.
Note that item 3 is available in different thicknesses, and ideally you should fit it all up, measure the clearance, and fit the right thickness of shim.
bodger
Post by bodger »
also if you have or had a manual gearbox on the engine you will need to remove the spigot bush in the end of the crank ...other wise the tip of the boss (item 2 ) wont fit :)
