symptom......running rich ...spark plugs ..black ..sooty ..wet ..
tried to set mixture by colortune ......can not get it to run lean ....
flame color shows running rich.......air screw in and out no change...
then I find my sump oil is contaminated with petrol ..
prognosis ....fuel flooding ??????? why .....
not sure if SU carbs (2inch bore ) are standard......NO ID numbers for reference ..
Im running a custom air intake with NO filters....
have cleaned carbs and set floats .....
im running a Facet pump...
fuel pressure reg ..= 2.5
tank return pipes clear ..
I get the feeling of a MISS MATCH ....needle to jet !!!!!!
any suggestions ??
