SD1 Stat bypass pipe???
Jono FD3
Post by Jono FD3 »
Hi guys, just a quick question on this.... I know what it does by the name, but is it really needed?? It's the only engine I have ever seen with a bypass pipe, so why is it needed??
Just trying to figure out if I need to re install it or not as the hole has been plugged on my offey manifold!
Jono
Darkspeed
Post by Darkspeed »
Yes - Its needed - and almost all cars have them
Andrew
4.5L V8 Ginetta G27
Jono FD3
Post by Jono FD3 »
I know there is a little valve in the stats themselves, but never seen a separate line??
ramon alban
Post by ramon alban »
Jono, have a butcher's at the PDF available from this link and see if it explains why there is a bypass!
http://www.vintagemodelairplane.com/pag ... ing01.html
from the foot of page 1 to halfway down page 2.
Or at least, whether we are talking about the same thing?
Jono FD3
Post by Jono FD3 »
Aha, yea, that's the one and I can see the reason for it now..... but if I were to take the heater feed from the back of the intake manifold and have the return going to the water pump inlet side, wouldn't this have the same affect as the bipass hose??
Talking of heaters.... where should the interior heaters return to as I can only see the outlet on my engine??
Jono
Meatus
My heater matrix returns to the water pump
Post by Meatus »
Jono, my heater matrix is fed from the back of the inlet manifold and the return goes to the water pump (on the left of the picture)
I hope this helps in some way.
Tim.
Return to “Cooling Area”
