Heater Hoses
Heater Hoses
Hi guys, the cappa has burst a heater hose,
and im not sure if its a capri hose or sd1 hose,
they are both like a stretched letter s if thay makes any sense?
any one got any pics of the back of there v8 in an sd1 think it would of been a carb layout if it made any difference,
and if so can you measure from the center line of the heater outlet to the center line of the inlet manifold outlet, i can then measure mine and see if its an sd1 hose set up on the rear of the engine in my cappa.
the heater hoses im looking for...
Get yourself 5 by 90 degree silicone bends and 2 straight copper pipes cut to the right length.
A bundle of jubilee clips and you are good to go
And if ever either fails again you gave a spare as everything is done solely in the 90 degree bends
i would rather save the money and have some made in silicone mate, less joints less risk of leaks
landrovernuts
- Helpful or Confused
cheers toby,
the hoses are now at Roose being made up in silicone,
didnt ask mate just said make them as fed up with the hoses leaking etc,
will let you know when i find out, we get a discount at roose anyways,
www.roosemotorsport.com
Custom hoses arent that dear really. The price is mostly in making the former.
Which I guess you could maybe do yourself if you had some pipe and could weld ?
I had Roose make one for me a few years ago, also heater hose from heater box to above the engine where they have 2 90deg bends.
The hoses arrived today from Roose Motorsport
https://www.facebook.com/photo.php?fbid ... 395d231ed7
and started fitting to the cappa,
https://www.facebook.com/photo.php?fbid ... 4ed2fa597c
cheers guys,
i got one hose wrong, the long length of 19mm id should of been 16mm id, spoke to Paul and he is shipping the correct hose out to me in exchange for the 19mm one
