head stud washers cracking....
Jono FD3
Just a quick one to see if anyone else has sufferd the washers cracking when torquing them up?!! And oddly enough the 3 that broke, cracked at 70NM.
Jono
Jono
- SimpleSimon
70Nm is only 51 ftlbs, something going wrong here because from memory the standard torque is something like 68 ftlbs for the long bolts. (Not the stretch bolts, I dunno about them!).
BTW Real steel sell washers that are suitable for the Arp studs, I would have thought that they would be OK for the standard bolts.
I take it that you lubed up the washers?
We used to break head bolt washers on a regular basis, while running! I had the engine set up for high cylinder pressures to boost bottom end and it was lifting the heads slightly, switched to the washers Real Steel sell and the problem went away. Later switched to ARP studs and have had no problems since. Try the Real Steel washers if you don't want to stud it.
Alan
Alan
When you say lower figure on the outer bolts I hope you mean something like 20 ftlbs or even better just don't fit the outer bolts at all.Jono FD3 wrote:they were second hand ones mind guys.....
What I did was match them with steel washers and put the steel ones on the outer bolts with the low torque setting and put the rover ones on the 10 main bolts!
Jono
Before anyone kicks off about this being a bad idea, Rover thought that it was a good idea to omit the outer bolts!
