Got this threaded hole
marcjagman
Post by marcjagman »
Got a threaded hole on my inlet manifold, to the left of the thermostat housing and facing the front of the engine. Can anyone enlighten me as to what it's for? I was thinking maybe electric fan thermo switch, can it be blocked of?
ged
Post by ged »
Temperature transmitter.
DEVONMAN
Post by DEVONMAN »
It looks like it goes straight into the inlet port so it will be for a vacuum take off for say a brake servo.
Denis
I think it's for the brake servo too.
ged
Re: Got this threaded hole
Post by ged »
[quote="marcjagman"]
My mistake, but from the description thought he meant the one as above. The one on the top of the manifold is indeed for the servo spigot.
Regards Ged
Yup - brake servo vac port.
marcjagman
er no, not brake servo it is in a waterway
marcjagman wrote:er no, not brake servo it is in a waterway
No its not!!
Its in the inlet runner. Its the vac take off for the brake servo.
The item to the right is the otter switch in the waterway for the rad fan.
harvey
Post by harvey »
The one on the top next to the Otter switch is for the servo, the one on the front next to the thermostat housing (which was the one the original question was asked about) is for the temp guage sender unit. The Otter switch isn't for fan control, it's for a choke warning light.
marcjagman
Hopefully this will save confusion as to what hole it is, I'm sure it's a waterway.
ged
Post by ged »
I was right!
Temperature Gauge Transmitter.
Regards Ged
softdash3.9
Post by softdash3.9 »
Rover P6 inlet manifold iirc :wink:
Regards
Royston
DEVONMAN
Post by DEVONMAN »
I think the confusion was due to the fact that there is an unpainted threaded hole in the first photograph which is not the one in question.
The hole in question is facing forward and is in the waterway and is for the temperature gauge transmitter.
The one on top of the manifold is for the servo take off and I believe a non return valve screws into it on some models.
Denis
DEVONMAN wrote:I think the confusion was due to the fact that there is an unpainted threaded hole in the first photograph which is not the one in question.
Denis
That makes more sense!!!
Temp gauge sender hole for sure :)
harvey
Post by harvey »
softdash3.9 wrote:Rover P6 inlet manifold iirc :wink:
I think it's early Range Rover.
Return to “Cooling Area”
