Paul, I dont use the term blah as being derisory, but just to represent the whole essay. So, trying hard not to be pretentious, having read it thro' three times its almost as tho' the final sentence (conclusion) has a massive erroneous conclusive/typo error and should have read:Paul B wrote:Ramon, here's the article that made me feel manifold vacuum was the be all and end all of vacuum controlled ignition advance, long, but interesting: (Blah blah blah) - followed by:
For peak engine performance, driveability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum.
For peak engine performance, driveability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to ported vacuum.
and if, perchance, that was the case, might it explain why your experiences and preachings were so embarassing and why, to my very limited experience in these matters, I followed almost everything in the essay except the enigmatic last sentence.
The essay also says.
This seems to chime with my supposition attached to Question #2 - ieMost stock vacuum advance cans aren't fully-deployed until they see about 15" Hg. Manifold vacuum, so those cans don't work very well on a modified engine; with less than 15" Hg. at a rough idle, the stock can will "dither" in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle.
Either way, Paul, thanks for the responses. Its probably only talking shop stuff, with little relevance to the OP's original problem or my local SD1 Efi universe but it all helps with understanding ignition systems which is my current mission.Question #2 - Have you any idea why that phenomenom was occuring?
I cant figure it out, but might it be because the manifold vacuum changes with engine load, this induces the dizzy vacuum advance system to oscillate on and off because the vacuum itself was being affected by feedback from the change in spark timing?
Many thanks,
Ramon
